Late Model Racecraft @ Pinks
114 turbo or 106?
Sr71BJjr-
You my friend are a total douch canoe! When you finally get your car done and you want to race people, make sure you show up on a radial and we'll show up on slicks since there is no difference in your mind! Is a 114 turbo comparable to a 106 now?? or how about c16 to pump gas? Maybe a 3000lb car to a 3400lb car?? Should i keep going?
My god how dumb are you?? You have obviously never ran a fast car on a set of drag radials. Ask anyone that has run drag radials with over 1500hp and how it works and how touchy they are. Yeah, once you get your **** dialed in you can be cutting some great 60's. BUT IT DOESN'T happen overnight.
I've had conversations about this with madman, josh, ohio boys. THE GUYS WHO have run radials. YOU being the almighty internet guy that you are ... Just try to think a little before you post stupid ****
oh yeah.. and for the record.... SLICKS DO NOT EQUEL DRAG RADIALS!! There is a reason guys with slicks cant run in the drag radial class!
AWESOME!!
Sr71BJjr -
Try that, it may help with your thick skull.Congrats Stephen, you have in fact set the bar for the T/A suspended LSX communty. I look forward to the challenge of resetting the bar. btw, is the car you are driving 25.5 or 25.2? I am assuming it is 25.2 and you are under 3200lbs.? Details pleeeeease!
Tom
Sr71BJjr -
Tom
Tom
25.5 is only good to 7.50
25.2 cannot exceed 3200lbs. (most all stock susp classes are at 3300-3400 for turbo cars so 25.2 cert is no good)
Slicks, DR's... hrmmm. Steve/Josh/LMR guys like to get out every weekend if they can, from the sounds of things they are mostly hittin' events that run slicks, nothing wrong with that right that's their own prerogative. The GM race isn't until October anyway.
Can you guys post a whole slip for us slow pokes to view?
114 turbo or 106?
Sr71BJjr-
This is all in good fun here..Hell you act like i just fucked your sister or something? I mean did you really get that bent out of shape over the DR vs slick post that i quoted from your boy?It is a fact that alot of the S.S. cars can go just as fast with the new M.T. DR as they can with a TT5.More effort maybe but it can be dun. Wolfe went 4.70's on both ,and if i'm not mistaken he held the S.S. record for 2 years...Please tell me again how dumb i am???
BTW: LMR went faster on a 91.5 than you guys did with your 106mm so compare that genius
Congrats guys keep up the good work.
