what CR would YOU run?
-Detonation
-Cyl. wall/head stud/gasket pressures to high
What exaclty is it about a lower CR that allows the engine to handle higher boost levels? Just because the cylinder has more open room to pack with air? I guess the cylinder pressure would get too high with the same boost and high CR?
Iron 370 w/ -11cc Weisco slugs
AFR225s
ST80r
dual meth kit, 91 California pump
I plan to boost anywhere from 10-14 psi. If I'm hitting the track on a hot day @ 14psi, I might just dump 5 gallons of 104 in for added safety.
