Question for tuning w/SD question.
Old Mar 12, 2008 | 08:36 PM
maxgee's Avatar
Default Question for tuning w/SD question.
I ordered HPTUNER VCM suite, but not the professional.
I want to tune using SD for my turbo set up.
I searched and found I can hook up a wideband to 55pin in the PCM or A.C. o EGR wire. I also see that I need a 2bar map sensor. Anything else missing?
Old Mar 12, 2008 | 09:09 PM
MECHAM's Avatar
LS1 Tuning for Dummies?
you have everything needed to tune...
Old Mar 12, 2008 | 09:17 PM
ls1_chevelle's Avatar
Whats the advantage to hooking up the wideband to pin 55? Is it a must do? I'm running a 03 6.0l with stock ecu. If I have to do this, which pin do I have to splice into?
thaaaanks
Old Mar 12, 2008 | 10:14 PM
MECHAM's Avatar
thaaaanks
it allows you to read what the wideband is seeing EGR for example is 0-5v...same as a wideband. so for me..i had to splice in the wire from the wideband. enable egr...was disabled. add the correct pid. this can be found in the tuning section and/or hp tuners forums
