FI, what to do about PCV system
If your on a budget, a nice way to do it would be have a -12 weld on installed on a valve cover and ran down to a catch can mounted on the frame rail. Moroso/allstar sells these breather catch cans that have a -12an port. Looks good and works great.
-Jake, I found the Moroso cans with the -12 ports. I was considering this anyway and will try it based on your advice. Is one -12 line running from one valve cover enough or do I need a line coming from each valve cover? Of course, installation would be cleaner and easier with only one line, if it is sufficient. Sometimes less is more. Also is there a need to put a check valve in this line?
ls6 valley to check valve to intake manifold.
cap off the rest of the plugs on the valve covers and put the stock oil cap back on.
call it a day.
goes... ls6 --> check valve |--> intake manifold
