StS kit on stock ls1.
He does take it to redline once in awhile and does put it in to boost freqently and enjoy the turbo. He is also conservative guy and leaves the boost at 5psi and stock rev limiter which is probably why he don't seem to have any problems with valve float . His engine is nearly brand new as it was slapping so gm replaced it. So his valve springs are super low mileage. I sold him my racetronix pump but as of last summer he did not install it. Sure he has over winter or will this season. He plans on alc/meth and intercooler and sure will upgrade the valve springs or swap out cams. And he tuned it from day one,think the sts comes with predator tuner and he put in the 42s right away.
So is he lucky? .maybe but from what I have seen its fairly hard to blow up the stock motors at 5psi if you run premium fuel and keep the rev limit at stock. That said I decided due to getting my turbo kit at end of season last year to do up a fully forged 408 with of course all support mods in my 99 and do it all in one big modfest.
So you can simply install the kit and stay out of it to keep it out of boost. Agree this would take a bit of willpower.
i have tweaked the tune but the car runs solid, runs hard and does not have any fuel delievery issues with the stock pump and the 42Lb injectors.
the only problem i found is that 42Lb injectors (SVO ford Green Tops) do not allow a good idle quality due to the injectors pulse width being to large if i make the pulse width less than 1.8-1.9 the car wants to go lean on idle.
I have kept a close eye on the AFR and Injector Duty and the most i have hit is 74%
if i did it again i would probably spend the few bucks and atleast get the boost a pump kit and get a Fuel presure regulator.
good luck with the kit. i like mine and i still happy with 5psi. Most the time
chromoly pushrods
sts kit
walbro 255 fuel pump
60 lbs injectors
blow off valve
intercooler
dyno tune
thats what I would recommend, thats what I had and it was a trooper! put 20k miles on it and didnt break a sweat
It's that there is NO ROOM FOR ERROR.
One leaky vacuum line, one over-rev, one hiccup in the fuel line, and your pretty LS is tin cans. Ask me how I and several other victims of the notorious #7 ringland know.
Do it right and save thousands, as well as weeks to months of downtime.
