fi engine oil
Old Mar 18, 2008 | 12:11 PM
MIGHTYMOUSE's Avatar
ive been using rotella for the past year or so, was a gtx guy before that. i accidentally bought some syn. rotella so ill be using that up somewhere along the lines as well
Old Mar 18, 2008 | 01:26 PM
Websy21's Avatar
Hey MM, so you've had great results running the non synthetic rotella? What weight are you using? I thought atleast the FI guys would be using synthetic no matter what brand. On the other hand, we should change the oil very frequently so I guess that explains non synthetic sufficient enough
Old Mar 18, 2008 | 02:38 PM
Hugger Z's Avatar
I am just using Mobil 1 here. But now you guys have me wondering a bit.....
Old Mar 18, 2008 | 03:56 PM
ddnspider's Avatar
Originally Posted by Websy21
Damn lots of opinions here, LOL - You aren't making it easy now
Why switch to non synthetic in the summer though?
its just a thicker oil and it gets HOT down in FL so figure it would help
Old Mar 18, 2008 | 04:48 PM
yea i feel like clean oil in general is better than fancy dirty oil, so i just keep it changed and use regular 10-40
Old Mar 18, 2008 | 06:03 PM
ddnspider's Avatar
i agree.i change my oil probably every 1000 miles if that.its too cheap not to stay up on it after you go beating on the car.
Old Mar 18, 2008 | 09:56 PM
Websy21's Avatar
Makes sense to me too, will have to take your word on it. Seems to be working for you so it will be more than good enough for me than Off topic but what filters do you guys use than since you change it more frequently? I've heard about the a/c delco and fram are crap after some decent miles but wouldn't it do the job if you changed it 2500k and less? I can't see myself going much over 2k on an oil change, especially for the minimal miles I put on in a year!
Old Mar 19, 2008 | 07:48 AM
i happen to use the pure one filters or napa gold, no particular logic behind those... some sort of premium filter but i do not generally look at fram or stp or k&n at all for some reason
Old Mar 20, 2008 | 09:15 PM
Websy21's Avatar
Thanks MM and friends, LOL, this was an informative thread as I was going to try running some full syn GC and call it a day but this believes me to think that you are on the 'right' track Makes more sense to me!
Old Mar 20, 2008 | 09:50 PM
yea, well do what makes sense to you. everyone has a slightly different boat to float
Old Mar 20, 2008 | 10:12 PM
frcefed98's Avatar
Shell Rotella T 15W-40 in the ol bird I get the box of three big jugs at the NAPA down the street from my house. NAPA gold filter as well.
*edit* non synthetic
Old Mar 21, 2008 | 09:58 AM
  #32
Websy21's Avatar
Right arm, cool enough for me, Napa it is
Old Mar 21, 2008 | 10:51 AM
  #33
Turbo302's Avatar
One thing about the "New" Rotella and other diesel motor oils, is they took out alot of the zinc since the "low emmissions" diesels came out. If you look at the bottles of the new stuff that is labled approved for 2007 Ultra Low Sulphur vehicles, it is not the same as the old Rotella.
Same goes for the Kendall oils. I use to run alot of the old GT1 Kendall back in the day (the green stuff), and it had alot of Zinc in it (for high shock loads).
The old school racers still recommend Brad Penn oil, as it is suppose to be the same formula as the old Kendall GT1.
http://www.bradpennracing.com/
What I still use is what someone else recommended...Castrol Syntec 5w50.
I noticed with the Syntec 5w50 that I do not get as much blowby and my actual oil consumption is less. I've been using the 5w50 for over 15 years and have never had a bearing failure...knock on wood.
I use it in all my performance stuff as well as my 220,000 mi beater snow plow truck, without any issues.
Tim
Old Mar 21, 2008 | 03:29 PM
  #34
Websy21's Avatar
Hmmm, the good info keeps coming........... I love it and more facts to prove the Castrol once again! Might have to test both out and see the difference!
Old Apr 15, 2008 | 02:14 PM
  #35
Websy21's Avatar
Went to Napa today, I had to ordre in the Gold filters but they had the pro select in stock. Didn't seem as good and they'll be in tomar.
However, I can only find 15w40 and not the 5w40 or 10w40 rotella T non synthetic. It only gets really hot for about 2 months where I live and more or less warm for the other 3-4 months that I drive. Will I be ok running the 15w40? Won't it be a bit thicker/harder on the engine, I thought that either the 5w or 10w would be better. If so I might have to get them to order that in as well.
Just curious, do you guys run the same stuff in your DD's or do you run something else. I know I like to put synthetic in my truck and will usually get away with changing it twice a year. Spring and Fall. Especially sythetic in the girlfriends truck since she usually forgets about it
Old Apr 15, 2008 | 02:36 PM
  #36
Pat-Man's Avatar
I've been meaning to ask this very same question. So I guess the over opinion is to use a heavier weight oil in a turbo'd car?
15w40 non-synthetic?
Old Apr 15, 2008 | 03:54 PM
  #37
Websy21's Avatar
Yup, unless someone tells me to run different, LOL
I'd like to find some 10w40 but I guess the 15w40 shouldn't make much difference. If I drive the car at this time of year it can be fairly cold out yet here in Canada is why I am wondering.
Old Apr 15, 2008 | 08:58 PM
  #38
Avengeance's Avatar
I run Castrol GTX.... been using it for years. Ill use a AC Delco filter if I can find it, if not I go with Mobil1 filter.
Old Apr 15, 2008 | 09:06 PM
  #39
smoke20's Avatar
I just switched from castrol syntec 5w-30 to Rotella T synthetic 5w-40. So far so good but its only been about 2 weeks I personally wouldnt run anything but synthetic with my turbo, the heat and abuse the oil takes i just dont trust conventional oil.
Old Apr 15, 2008 | 10:17 PM
  #40
Websy21's Avatar
Hmmm, I'll have to check and see tomar if they can order me some rotella 5 or 10w40....... they said they only stock the 15w40. Seems like its a bit tougher to get some things in our stores in Canada compared to the US
