bigger crank pulley??
Old Mar 18, 2008 | 10:53 PM
Rickys S/C Z28's Avatar
Default bigger crank pulley??
were can i get one for a 6 rib set up ?? i was told that if i get a bigger crank pulley then i could make more boost out of the P1SC, so do any of you know were i can get one at?
Old Mar 19, 2008 | 12:59 AM
DeltaT's Avatar
I've used these guys twice with good results, for 8-rib pulleys: aspracing.com
Jim
Old Mar 19, 2008 | 04:43 AM
EPP's Avatar
EPP
I recently heard that ASP does make a 8.0" dia ProCharger 6 rib crank pulley. Bob
Old Mar 19, 2008 | 06:45 AM
ok bob thanks im going to call them to day
Old Mar 19, 2008 | 09:20 AM
WHPLASH's Avatar
I called. They don't but they can make one. 4 week lead time.
Old Mar 19, 2008 | 11:55 AM
ok thanks
Old Mar 19, 2008 | 12:43 PM
WHPLASH's Avatar
Pretty pricey too. $350
Old Mar 19, 2008 | 12:45 PM
trey04gto's Avatar
I have an 8" crank pulley ordered from ASP currently. The 4wk wait time is worth it!!! Say goodbye to belt slip and say hello to max blower rpm!!!!
 Michael S. Palmer
Old Mar 19, 2008 | 01:15 PM
im good on the 4 week wait time it the 350.00 i dont like, what kinds boost you running??
and do you think it would be good for a P1SC or would it be to much?
Old Mar 20, 2008 | 04:53 AM
EPP's Avatar
EPP
$350.00 is about right. I sold my used Mike Morgan 8" 6 rib several years ago for something like $200.00. Bob
Old Mar 20, 2008 | 06:35 AM
i think i might get this in a few weeks, will this max out my blower to the point were it will "hurt" it???
Old Mar 20, 2008 | 08:25 PM
9silverbird8's Avatar
FWIW, I have an 8" MMS 6-rib, and I still get pretty mad belt slip @ about 5k RPM and up. IMO just get the 8 rib. I don't see why the 8" APS pulley would be any different from the 8" MMS, probably still slip.
And no, it wont hurt your blower unless you pulley it up too much and exceed the max rpm of your P1.
Old Mar 20, 2008 | 09:10 PM
Z06PSI's Avatar
I think I have the 8" 8 rib Innovative going on the new motor.
Old Mar 21, 2008 | 06:41 AM
WHPLASH's Avatar
I have the MMS crank pulley too. Its 7.875" Going to an 8" is really no difference.
Old Mar 21, 2008 | 12:05 PM
well that dont sound good why do you still have slip?
Old Mar 21, 2008 | 12:47 PM
DeltaT's Avatar
I rarely see people slip at the crank pulley - they go bigger at the crank so their blower pulley can be bigger and avoid slip. Is that what you are thinking?
Jim
Old Mar 21, 2008 | 01:21 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Why bother dumping more money into a 6 rib? Just invest into an 8 rib setup!
Old Mar 21, 2008 | 01:49 PM
Z06PSI's Avatar
Go ahead and buy an 8-rib. You can always run a 6-rib belt on the rest of the system until you need to upgrade all the pulleys to 8 rib. Mine is running just fine like that until my alternator and power steering pulleys are made.
Old Mar 21, 2008 | 02:10 PM
ChevyChad's Avatar
The f-bodies don't even have that issue since they have a dedicated pulley for the supercharger...
Old Mar 21, 2008 | 10:11 PM
NemesisC5's Avatar
I did not see if OP car is a Corvette or F-Body, BUT....I AGREE with these guys...don't waste money on 6-rib, it's inevitable one day you will pony up for an 8-rib setup. At least on a 8" crank pulley you just have 2 extra ribls till you have the coin for the rest of the setup. Good Luck
