fi or carb more power?
Old Mar 22, 2008 | 01:48 PM
daniel6718's Avatar
Default fi or carb more power?
does carb setup really make more power...i really dont understand how and i dont believe it so its getting old to me...
i would with FI with perfect a/f all the time and perfect tuneup all the time it would always make more power
Old Mar 22, 2008 | 02:33 PM
Mr.MartyStone's Avatar
Perfect??? That's a pretty defined term to be throwing around. The drivability is usually better with an EFI setup due to the ability to fine tune certain parameters. But usually a blowthru will make more average power in the way the fuel is drawn into the runner. It acts as an i/c of sorts. EFI you have 60-80psi of fuel presure. Put anything under pressure and it heats up, which in turn decreases power output.
Marty
Old Mar 22, 2008 | 02:50 PM
deadmanTA's Avatar
It prob would on a high reving race setup with a big cam, but I wouldn't do it for a street setup myself.
Orignally posted by: daniel6718
i would with FI
This is the FI section, most in here are. Prob be better asked in the External section, unless you are planning to boost your ride.
Old Mar 22, 2008 | 04:51 PM
Seems like he is just asking a question, not looking to swap to a carb. Trying to feel better about owning an EFI car.
Old Mar 22, 2008 | 05:01 PM
Rock_Daddy's Avatar
From what I have read over the years it seems EFI is better in every way execpt wide open throttle. At WOT a carb can pull a small advantage. IMO
Old Mar 23, 2008 | 07:33 AM
deadmanTA's Avatar
Hell using 3 times less gas should be enough then! You have more control over the motor in an EFI setup. You can still use the intake and keep the EFI also, that what the FI guys are doing.
Old Mar 23, 2008 | 10:49 AM
stevieturbo's Avatar
There are some old school people who think carbs are better.....
But everyone else knows they arent
Old Mar 23, 2008 | 01:27 PM
camarols1's Avatar
+1 For EFI
My last setup was a blow-thru carb setup and while it wade great power, it was a real PITA to tune on the street.
It is difficult to get the part throttle throttle fueling perfect on a carbed FI setup.
I have the boxes of holley jets to prove it !!!!
Unless you are class racing where they give the carb guys a weight break, there is no advantage at all besides gray hairs....LOL
Stay EFI and save yourself a ton of grief.
Old Mar 23, 2008 | 10:46 PM
daniel6718's Avatar
i meant to put this in fueling an injection...can some1 move it...
it meant efi vs carb
Old Mar 23, 2008 | 10:57 PM
kp's Avatar
kp
The air mixing with the fuel in a carb gives an intercooling effect and also is usually a little better atomized. So in theory a carb has the potential to make more power.
But the ease of tuning and somewhat infinite adjustability of EFI will give you better starting and driveability and cleaner emissions. Nothing against carbs myself, I have used them for 30 years, along with EFI and mechanical injection and I'll keep the EFI even if its loosing a few HP. Having to deal with needles and seats, changing jets, accelerator pump squirters/cams, air bleeds vs just sitting there with a laptop makes EFI pretty appealing.
Not to mention, as a lot here probably didnt experience, stock carb'd daily drivers in the wintertime were always a crapshoot getting to start. The days of a shop full of cars that were flooded on a 20 degree day is long gone..
Old Mar 24, 2008 | 02:18 AM
EPP's Avatar
EPP
lol, no doubt! Bob
Old Mar 24, 2008 | 09:35 AM
deadmanTA's Avatar
Definatly EFI!
I had a 454 back in HS and it took longer to crank it and get it to idle than for me to get ready for school.
Old Mar 24, 2008 | 10:55 AM
kp's Avatar
kp
I lived in Chicago and all it took when it was below 20* was a stuck choke pull-off plus a few cranks and your car was sitting inside a shop with the crankcase full of gas and 8 gas soaked plugs. Starting a car when it was cold was an art even when everything worked as it should, but a lot of drivers arent artists.
Or when it got really cold out (below zero) I remember heating up my fuel lines with a blow drier and having a pan of charcoal under the oil pan so the thing would even crank over - the good old days..
Old Mar 24, 2008 | 02:57 PM
camarols1's Avatar
I'm still in Chicago and my carbed SBC was no joy to start in January that's for sure.
I was lucky enough that I never had to resort to the Weber grill treatment!
Efi for driveable power
Carb for ultimate HP per dollar....
Old Mar 25, 2008 | 08:15 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Inventing time travel would be slightly easier than that
Keith
Old Mar 25, 2008 | 12:17 PM
daniel6718's Avatar
i was getting at when its cold out there no problem starting...it desont run rich...high altitude it doesnt run rich ect ect
