What would cause me to lose HP?
I looked up the specs for the ram and it says its rated for like 1000 and thought read thats rwhp? and 900 torque again thats rwtq? So it should be fine. But as said if not adjusted right it could be slipping and burning itself up pretty quickly.Its not adjusted right or not bled right if you are having trouble with 1st and reverse.Those are the gears that really tell you if you have problems.
I know for a fact a clutch can lose couple hundred hp. I can't see timing or even afr losing that much. And can't see engine being pooched with no smoke coming out or bad noises. But blowing out the spark could kill power for sure. Too bad its still fairly annoying to do plugs in the ls1 but better than some cars. So how is plug access with the aps manifolds? Looks like it should be good.
I looked again at aps threads and they did dyno their forged up 346 .They also listed their timing and their afr but they were running meth/alc injection. They also didn't mention plugs. Their compression ratio was 9.2.
Well my boost is hitting 14.2psi so I'm guessing that means both turbos are working fine.????
I'll try and pull a plug or to today, what should I look for ???
Hopefully clutch is ok still.
Problem with dual turbos is if one is not working the other one could maybe make up for it making it hard to tell. I would think best way would be to somehow take off outlet pipe from the one turbo and block it with something so only one turbo feeds the engine but then this is only feeding off one side of the motor. Or if guy can open the gate so the one dont' actually boost at all. Not sure how to check turbo output when you have two. Its easy with only one. And easy to make gate open on internal wastegates.Just wire it open.
Still again if you got 14psi in there you got 14psi but its not psi by itself that gives the power its airflow. 20psi on tiny turbo is not 20psi on bigger higher flowing turbos.
So simply looking at that number is not going to guarantee much dont' think if the one turbo is not flowing air and contributing it share. Again I have only had single turbo cars so far.
I do now that excessive play normally causes lots of oil coming thru the exhaust thru the turbo seals. Head gaskets blown normally cause lots of white smoke. Blown engines also cause usually lots of oil when ringlands let go but you have forged pistons not stock hypercraps.
What fuel are you running? Are you running alc or meth injection. Think setting alc or meth injection wrong can also take away power. Beg,buy or borrow a scanner and start looking at your timing ,knock retard and even narrowband 02s and other values. Buy a wideband right away and keep one in the car. We need more hard data now to really help you out.
Chris
Chris
But if he blew head gasket he would see white smoke and if he blew pistons he would see lots of blue smoke and of course would have no compression in there .
He has lots of things to check. First get the clutch engaging and disengaging right. Then check his plugs to see what at least some of them look like, check for boost leaks,see whats up with that one mabye pooched turbo, scan the car and look at knock retard,timing and wideband it for afr.
Also possibilty maybe is the intake tubes sucking shut at 14 or more psi. It is possibly an issue if you read the other threads on the subject.
Personally if it were my vehicle, i would verify the integrity of the motor before doing anything else. You dont just loose 200hp in plain air.
This car being a GTO, the inlet tube will not suck shut, it has a re-enforced tube. Also, it did make full boost.
Also, one turbo is not enough to make 600-700hp, so im guessing its not the turbo.
Unless you went stark rich, there is something else thats up.
Blown engines blow blue or white..and lots of it. Take out ringlands going to blow lots of blue. But these are forged pistons.Should take some detonation. Maybe they left timing stock who knows? We need more info for sure. Be nice to see dynos and afr and be nice if he had a scanner or did some logging. So since this is a f body can't his intakes be sucking shut? You guys already had that problem on the car you did right?
Here is his sig..
1999 Camaro SS #208
APS Twin Turbo-Katech LS2 402 Stroker 720rwhp @13psi
I'd check the turbo(s), easy enough to pull off for a thorough inspection. Have you checked for any exhaust leaks from the exhaust manifolds to the turbo as well?
Here is his sig..
1999 Camaro SS #208
We have encountered the ducts sucking shut on two cars.
What happens is the boost rises up, then cuts basically in half (we had one turbo side suck shut). If they graphed boost against rpm you will see it.
The only reason for me posting this up is to get other feed back from other people. I'm not one to just go pull a turbo off right away. And if it easy then yeah I would go pull it off, but I dont have time nor would I like to do it, due to the fact I just put the bastards on there and its not easy. If the turbo or turbos are bad then I will pull them off but I would like to rule out everything else first.
