epp f1a kit..
Old Mar 31, 2008 | 10:02 PM
white99ta601's Avatar
Default epp f1a kit..
can you keep the a/c or do you have to delete it... trying searching but didn't get any results but i could have been searching the wrong thing..
Old Mar 31, 2008 | 11:29 PM
02NBMFormula's Avatar
youll need space to fit the f1 in there so most people lost the ac and move the radiator forward.
Old Apr 1, 2008 | 01:07 AM
Jimmy P's Avatar
You can make it all fit if you REALLY want to. The main thing is getting a good size intake elbow on there. The stock procharger one is small and extremely restrictive, but does a good job of fitting in that tight space.
Old Apr 1, 2008 | 04:33 AM
EPP's Avatar
EPP
Thumbs up
KP has experimented with the elbows and said he his track times and mph did not find a difference by swapping them out. It seems the biggest difference comes from swapping to a larger air filter. Bob
Old Apr 1, 2008 | 06:23 AM
speedracer5532's Avatar
It can be done but it definitely takes some modifying to get the condenser in there. I am running a Griffin radiator which is alot wider than the stock radiator and I was able to make it all fit running a F1A blower.
