What head gaskets with 15-17 PSI
Right now I have the 6.2 5 layer gaskets.
I know KP has them on his car and they are holding up so far as well.
Glenn
I have a set of the GM mls 02-04 zo6 head gaskets that are suspose to be good, I will be using ARP head studs.
I was thinking of the Cometic Phuzion LS1 boost head gaskets , they are expensive but are suspose to prevent head gasket failer in event of head lifting.
whats do you think?
The extra gasket material you speak of will not do anything for you since it is not sandwhiched between the block and the head, and left exposed from the larger chamber on the head.
Let us know how your set up works out.
Glenn
Glenn
Sorry to ***** hummer, I'm just stressin now that this thing isn't gonna last longer than break-in now
02- I tried searching last night to see what other have experienced and the search was lacking. Today I came up with this, but you should be able to search for more info.
https://ls1tech.com/forums/showthrea...=mls+heads+317
Hopefully everything works out for you.
SS1-I am not sure but I think you are right on the sizes. However you can run both gaskets on the 3.90 bore. I have run both, but have not boosted the 6.2's hard yet.
Glenn
