Update:Need some Help with my build!!!
Old Apr 11, 2008 | 11:41 PM
BlackCamaroSS02's Avatar
Default Update:Need some Help with my build!!!
This is the original post https://ls1tech.com/forums/showthrea...287&highlight=
Turns out i found what the problem was, my brand new sheet metal elbow that mates up to the victor jr series manifolds cracked right down the weld on one side. I figured thats how i could be loosing PSI lol. I have to find out who made it cause that shouldn't happen i didn't even drive it 500 miles lol. Must have been a bad weld.
Anyone know what i can do to patch the thing? have a welder re-weld it?? I really don't want to take it off the car.
Old Apr 12, 2008 | 12:03 PM
70Stang's Avatar
It could easily be rewelded by any good welder. I would recommend taking it off the car tho...
Old Apr 12, 2008 | 12:11 PM
BigJls1's Avatar
^ yeah because in order to do a proper repair they should grind a grove in it where the crack is, in order to get better penatration.
Old Apr 12, 2008 | 01:09 PM
jerrad's Avatar
Also, he could melt the intire electrical system putting that much voltage through the car.
Old Apr 12, 2008 | 10:13 PM
Yea good point ill take it off and have it re-welded. At least its an easy fix. im still going to check the vacuum lines and see if anything is loose or came off.
Thanks everyone
Old Apr 12, 2008 | 10:25 PM
theblur98ss's Avatar
It shouldn't be any big deal. A few bolts and it's off.
