Balancer Bolt Loosening?
Old Apr 13, 2008 | 10:44 AM
FastBlackTA's Avatar
Default Balancer Bolt Loosening?
I recently built my forged LS2 motor for my corvette. Nothing special, just manley rods and a set of mahle pistons, GT-11 cam, stock heads, APS TT.
When I turn the boost up to my normal 13+ psi, my balancer bolt comes loose and the balancer actually moves forward which then kicks the belt off. This has happened twice in 50 miles or less, and both times I used a new balancer bolt torqued to 240 ft lbs.
The only thing I can think to do at this point is key the balancer. I have a leftover procharger crank key for an LS1 vette. What do you guys think?
Old Apr 13, 2008 | 10:49 AM
Pat-Man's Avatar
I was about to say you might need to key the balancer. For some reason though I thought that was for supercharged systems only. I may be wrong though.
Old Apr 13, 2008 | 01:46 PM
Something tells me that the press fit balancer has enough inertia to overcome the friction/pressure of the press fit design. This only happends when I'm hard on the car and doing 3rd and 4th gear hwy pulls.
Maybe the rpms climb so fast when the boost ramps up that the inertia of the balancer tries to keep it in place while the crank wants to accelerate as fast as possible?
I have never had this problem before....but that being said my nitrous t/a has a keyed balancer so there must be a reason for it.
Old Apr 13, 2008 | 01:51 PM
DuronClocker's Avatar
Key it, that'll stop it.
Old Apr 13, 2008 | 02:00 PM
Are the procharger crank key kits for the ls1 and ls2 interchangable?
Old Apr 13, 2008 | 04:37 PM
I *think* so..
Old Apr 14, 2008 | 07:57 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Yes
Keith
