oil feed and return PARTS LIST
(3') of -10 stainless steel braided hose
(2) -10 AN Straight hose ends
(1) -10 Oil pan adapter
(1) -10 X 1/2" NPT adapter
(1) billet aluminum T3/T4 oil drain flange.
Oil feed line are Pre-made High pressure line. Usually -3 or -4 and fave fitting for 1/4 NPT fittings.
I have a Turbonetics T76 for my LT1 and it's frontmounted so I suppose the 3' of line will work. Click on the link below to see the layout of my hot side and the mounting of the turbo if you want to make an educated guess on that length. The bulkhead adaptor is positioned at the top/front/right (when facing the Harmonic balancer). The pan was originally setup for a Vortech S/C so the position of the drain adaptor is commensurate with that kit.
http://www.taekwondoplus.org/z28/Tur...boHotparts.htm
