custom pulleys??
Old Apr 14, 2008 | 12:22 AM
Rickys S/C Z28's Avatar
Default custom pulleys??
i have a buddy that can make pulleys, and what im wondering is if i have him make a 3.00 8 rib pulley and a 8in 8 rib pulley will that make 10 ps1 from a P1sc? or will it be to much for it?
also is there any one making 10+ psi from a P1SC? if so how? thanks
Old Apr 14, 2008 | 07:39 AM
WAHUSKER's Avatar
Well it might make 10 psi (it depends on your entire setup), I've seen a P make 8-9. But at 6k rpm on the engine you'll be spinning the blower to 65,600, which is past it's 62,000 redline. So it's a bad idea unless you plan to set your shift points to 5500 or so.
crank pulley divided by blower pulley times 4.1 times engine rpm equals blower speed
Old Apr 14, 2008 | 01:41 PM
DeltaT's Avatar
Although going 5% (approx from your numbers above) above redline occasionally shouldn't kill the blower.
Jim
Old Apr 14, 2008 | 08:16 PM
what happen if you over spine the head unit?and WAHUSKER thanks for the formula
