Alky control/Map sensor question
Old Apr 16, 2008 | 08:00 PM
theblur98ss's Avatar
Default Alky control/Map sensor question
The alky control kit has it's own map sensor. Do you need another one for the car or will the one with the kit work the meth and the car?
Old Apr 16, 2008 | 08:12 PM
Jake@EPP's Avatar
I have set it up to run off the 2bar sensor. The 3bar should be do-able just run the green wire for the alkycontrol kit to the output of the 3bar, and also a 3bar tune if not using a stand alone.
Old Apr 16, 2008 | 08:48 PM
I'll be using BS3 and need a 3 bar map which is what my alky control kit has. So I can just slice my BS3 harness into the wires from my alky map sensor and everything will be happy?
Old Apr 16, 2008 | 09:07 PM
Jake@EPP's Avatar
Yes sir, if you dont feel like cutting wires, i can supply you with an adapter harness with a tail.
