Injector Options for larger injectors
Old Jul 31, 2003 | 10:37 PM
Redline-Motorsports's Avatar
Default Injector Options for larger injectors
Just finishing up a blower motor project in a 99 GMC P/U. It is a 5.7l with a ATI Procharger pushing 14 psi of boost. I noticed that the stock injectors have different connector ends then the traditional style used on the LS1/LS6 motors. What do I need to do to run a 42 lb/hr injector with this setup? It also looks as if the actual size of the injectors is different. Could the LS1/LS6 style harness ends be used with the same family of injectors? Could the fuel rail be shimmed?
Old Aug 2, 2003 | 08:55 PM
Default Re: Injector Options for larger injectors
What no ideas??
Old Aug 2, 2003 | 10:13 PM
GMC SKI's Avatar
you can get 42lb injectors that drop right in from racetronix's they are a GM marine injector
you Can also buy some injector connectors from racetronix's and splice in some injectors you will have to shim the fuel rails up
there is actually a tech article for this
by Xlr8nss do a search in the truck forum
jim
Old Aug 2, 2003 | 10:54 PM
ArizonaSpeed's Avatar
I added the injectors to our website if you need them. Go to www.azspeed.com They are on the front page at the bottom or in the truck section.
Old Aug 3, 2003 | 12:20 AM
XLR8NSS's Avatar
Adkoonerstrator
9D9LS - Don't even worry with the direct fit injectors. They will not be enough for a 5.7L with 14psi. The 42# direct fit injectors are rated at 4bar so they are true 42# injectors. A 42# SVO injector is more like a 50# injector at our fuel pressure(4bar).
The injectors in the trucks are different as you've found out and to put normal injectors in you will have to do some customizing to the fuel rail and injector connectors.
Here is a link to the little "how-to" post I made on converting over to regular injectors.
<a href="https://ls1tech.com/threads/showflat.php?Cat=&amp;Board=UBB18&amp;Number=60834 1&amp;Forum=UBB18&amp;Words=injector%20conversion& amp;Match=Entire%20Phrase&amp;Searchpage=3&amp;Lim it=25&amp;Old=3months&amp;Main=608341&amp;Search=t rue#Post608341" target="_blank"><font color="red">Click Here<!--color--></font></a>
If you have any other questions or want a different pic of something let me know.
John
PS - I'm running 42# SVO injectors and can give you a base tune for them if you decide to run them.
