Starting Problem - Fuel Percolating??
Old Aug 2, 2003 | 06:18 PM
ChevyNo1's Avatar
Default Starting Problem - Fuel Percolating??
After I shut the car off, if I try to start let's say 1/2 hour later it will barely start. Sometime it will crank and crank, and barely catch when I let off the key, then it stumbles to life. I've got a boost-a-pump on it, but the fuel pressure is fine while cranking . . . any ideas? Once the car cools down it's fine . . .
- Dug
Old Aug 4, 2003 | 12:18 AM
1dirtyZ's Avatar
Default Re: Starting Problem - Fuel Percolating??
bad regulator?
Old Aug 4, 2003 | 12:00 PM
red ws6 99's Avatar
Definetly could be a little heat buildup. My car is definetly a little grumpier to start when its warm. It starts, I just feel a little hesitation.
Gary
Old Aug 4, 2003 | 12:37 PM
ChevyNo1's Avatar
Hmmmm, it's irritating, and sure doesn't make my car seem like a performance car ( or does it ). If it was a bad regulator wouldn't it give me problems other than then?
- Dug
