stock boost
Old Apr 25, 2008 | 02:18 AM
glennxx1's Avatar
Default stock boost
what boost could an internally stock C5 handle? or even 4 pounds will end up killing it eventually?
Old Apr 25, 2008 | 02:45 AM
verve_v's Avatar
You can do up to 8 lbs with and intercooler, tune, and most likely methanol semi safely. The safe line is 5 lbs with a good tune. Remember, adding any sort of boost is prolly going to reduce the life of your engine. Especially since boost is more addicting than crack
P.S. Search it, you will turn up thousands of results.
HAPPY BOOSTING!
Old Apr 25, 2008 | 04:56 AM
EPP's Avatar
EPP
We set up the ProChargers for 7 to 8 psi of boost, which averages an 140 rwhp increase. With a good tune and good gas you won't have any problems. Check out these cars.
http://www.exoticperformanceplus.com/hotCars.php?car=67
http://www.exoticperformanceplus.com...Car.php?car=46 Bob
Old Apr 25, 2008 | 12:16 PM
BLNLS1/RX7's Avatar
Bob said it all right there.
Old Apr 25, 2008 | 12:37 PM
tomz28's Avatar
im pushing 11 right now its holding up good so far tune is key
