Procharged 370 GTO falls on its face?
Logs in post #13
Valvesprings are T.E.A's dual gold springs good to .650 lift
Fuel pressure never drops off...(a1000 pump, rails, boost ref regulator etc.)
Wait, since my regulator is boost referenced and now im making alot more boost my AFR should still be close just on the regulator making its own adjustments right? Since my Wideband is not working I fattened it up a little in the Power enrichment tables to be safe. That increase plus the increase in fuel pressure could make it do this correct?
Not if, as mentioned, there are fueling problems...
Pump taking a dump?
When this happens,FP is?
Plugs look like?
Good Luck
About the TB closing... On a cable driven TB how is that even possible? How is it fixed?
Geezer, Fuel pump is good, pressure steady and climbing under boost and plugs are pretty damn dark...
Bye the way thanks fellas!! I will get you some better info ASAP
"He looked at the log and said at the wide open spot where it cuts out the TPS % goes from 100 to 0 ??? That is exactly what it feels like."
I don't use HP, so I can't look at the logs, but hopefully someone else can.
Without a continous TPS signal.. I'd start there.
Can't you just hook up HP, connect, key on, engine off, and look at a dashboard that has TPS on it, and see if the signal is smooth and continous??
