Tilton Oil Pump Leak
Old May 3, 2008 | 08:35 PM
JerikSS's Avatar
Default Tilton Oil Pump Leak
I have a leak,,
Oil is leaking from the two square holes below the clamp that holds the bracket. What can I do to fix this, or do I need a new pump.
Help please.
Old May 3, 2008 | 08:40 PM
Jake@EPP's Avatar
Tilton sells re-build kits for these.
Give tilton a ring and they will direct you to one of there vendors whom sell the kit.
Old May 3, 2008 | 08:54 PM
JerikSS's Avatar
There are two kits but I need to know which on the Check Valve and O-Rings, Replacement, or the Diaphram and Pistons, Replacement, Buna Rubber.
can anyone help?
Old May 3, 2008 | 09:05 PM
JerikSS's Avatar
Does it matter how its placed. I have the hoses at the bottom, should they be on the top???
Old May 11, 2008 | 11:26 AM
JerikSS's Avatar
Is it possible its not getting enought voltage, I am getting the power from the smog pump wire??? Like I said the oil is coming from the mid part of the pump where the two square shape holes right above the clap that holds the mounting bracket. anyone...
By Brett Foote | 2026-06-04 05:00:17
