408 sts.. Need input
I'm getting a built 408,custom cam, w/ a 9.1 cr w 241 heads,intercooler,okay I was planning on runnin my 60 trim that I got from sts, is the turbo to small...any input is apprciated.... Oh yea looking for a 12 bolt rear end
WAAAAAAAAAAAAAAYYYYYYYYYYYYYYYYY too small. Not sure what size snail to run for a rear-mount on such a large cube motor :whoknows:
EPP knows their ****......http://www.exoticperformanceplus.com...Car.php?car=32
GTS 76 Is what I run on my4xx. .80 AR Full boost 7 psi at 3400 six speed 3.73,1 gears. If you get another turbo the stock intake pipe in the rear will not work. I also used epp for a referance on my build. Car mad 610 on 7 psi.
I wont retract my previous statement about the sts setup but I will say if you're going rear mount a custom setup would be the only way to go for me. There a couple guys on here running st80's out back with good success so far.
ST80 is alot of turbo! great for top end power. But you need to do some custom work to feed that beast trust me LOL! Good luck. Jose at force inductions will set you right. I got what I wanted low lag and mid to top end pull.
bringing this thread back....anyhow im getting a performabuilt stage 3 4l60e tranny.....i have a 3200 vig converter..is this to much stall.....got a 408 w/ a garrett t76 in the rear.....what are you guying runnin as far as stalls???thanks.....
