AEM boost controller very notchy feeling....help
Old May 6, 2008 | 07:18 PM
MeanYellowZ's Avatar
Default AEM boost controller very notchy feeling....help
Just finished throwing in an AEM boost controller and have been rewarded with some very erratic ( I call it notchy ) boost. I havent ever messed with one of these so I could used some help. The instructions werent real helpful (at least to me)
I set the "spring pressure" deal around 7.5 because that is supposed to be what the spring is set at in my JGS gate.
Then I played with the a and b duty cycle which the instructions suck on but Im guessing that is how you set boost levels?
With the setting in off, I get a very smooth 5 lbs of wastegate only boost with no issues.
I set "a" at "39" for starters at i get just under 9 lbs of very erratic boost that keeps building and letting off, over and over very rapidly and annoyingly like the solenoid is the slowest responding thing. I set "b" at "18" duty cycle and pretty much get the same results as "A" does
Am I super dumb? About to rig up a nice manual BC, at least it would be smooth.
Old May 6, 2008 | 09:04 PM
CrazyChris's Avatar
There are 3 settings on the AEM. Off, A & B. If you see 5lbs with the controller off, that is what is your gate. Set spring pressure to 5 on the controller. Then setting A & B are on a percentage base higher than the base 5lbs. Generic rule of thumb is a controller can double whatever spring you have in the gate. So anywhere 80% and higher I would guess you to see 10lbs.
