will it float the valves on 5 to 8psi
Old May 7, 2008 | 08:41 PM
Sideways240sx's Avatar
i got a gt4276 and at 6 psi im floating my springs.. Except i dont plan on keeping this motor or heads for more then about a yr, so i didn't get duals. Im going to throw in ls6 yellow springs(they were a freebie) and i got texas speed 7.4 push rods. I am gonna throw in the springs this sunday, and then i should.. maybe. hopefully be back on the dyno the foloowing week, and will try to let you know how they do.
Chris
Old May 7, 2008 | 08:46 PM
52172's Avatar
what the average or close to best open and close seat pressures for FI? Regardless of spring type.
Old May 7, 2008 | 08:56 PM
witry's Avatar
yeah let me know i prob wont start the install till like 2 3 weeks so get back to me see how they do
Old May 8, 2008 | 07:18 AM
Stang's Bane's Avatar
Threre is no one answer for this question. It all depends on your valve train. The heavier your valves are the higher spring pressure you need. Spring weight, locks, retainers, all figure into this as well. I would err on the side of a little too much spring pressure though.
Old May 8, 2008 | 07:43 AM
ls1290's Avatar
Dumb Ass Vette Moderator
One of the biggest factors is the type of cam you have. The cam's lift and ramp rates play the biggest part. If you have a stock cam, LS6 or 918s springs will be fine for 5 to 8 pounds of boost.
Keith
Old May 8, 2008 | 11:32 AM
Reject's Avatar
when would you look to get the duals then for a stock cam but at say 12 pounds?
im going to stab some dual patriots just because i have them from my ms4 days, but was wondering when you would concider them for a stock cam at alittle higher than 8 psi
Old May 8, 2008 | 11:37 AM
ls1290's Avatar
Duals certainly would not hurt. Plus it is kind of cheap insurance if you break a spring. If a spring does break with duals, the second spring will help keep the valve from dropping.
Keith
Old May 9, 2008 | 08:07 AM
Hugger Z's Avatar
I am running the yellow LS6 valvesprings with my stock cam on 7psi of boost. Upgraded to TSP hardened pushrods at the same time. No issues with my set-up. And definitely affordable!
I did the install in the car with the dual spring tool and the cylinder pressurizer fitting. Worked like a charm.
Old May 9, 2008 | 08:22 AM
witry's Avatar
thats my set up here stock cam and only 5 psi DD and 7 psi sometimes but like ls1290 said its cheap insurance with the duals if one were to breaks you got the other to support the valve but im on a tight budget here and the LS6 yellows are next to nothing but the patriots for 255 are kinda cheap too such a delema but the Yellow LS6 do sound good to my wallet not to sound to cheap here
