turbo filter restriction
Old May 8, 2008 | 09:16 PM
Sideways240sx's Avatar
When i get my valve springs done, i may pull the filter off, and see if the power goes up. For the street i will keep the filter on, just as a saftey measure. This is what i run, it was the biggest i could fit.
Part Number: KNN-RU-2800
Air Filter Style: Conical
Length (in): 7.000 in.
Inlet Flange Inside Diameter (in): 5.000 in.
Air Filter Top Measurement: 4.375 in. diameter
Air Filter Bottom Measurement: 6.500 in. diameter
Think its big enough?
Old May 8, 2008 | 09:28 PM
Dbluegoat's Avatar
i have 2 pieces of screen from home depot, doubled it and my turbo STILL sees some restriction from it, so much in fact it literally sucked in the screen on the dyno and wore a hole thru the middle of the screen right where the shaft is on the turbo.
you would think screen would not be restrictive but it is, that said any type of regular filter will probably suck bad
Old May 8, 2008 | 10:06 PM
Reject's Avatar
Originally Posted by 70Stang
I agree with Veee8 that the AEM Dry flow is a great filter - we have actually GAINED HP from adding the AEM over NO filter at all.... !!!
which ones you talking about got a link?
Old May 8, 2008 | 10:42 PM
camarols1's Avatar
Originally Posted by ls1_chevelle
hahah I was waiting for that question.
I had a friend tig weld the v bands on. The process took about 5 hours total welded inside and out. Zero warpage. Proper rod, pre heat, maintain heat, post heat. All done with an oven for 100% even heat dispersion.
Thanks for the comments. It was fun and very interesting. Was my first turbo system that I fab'd and welded myself.
Good thing it was a friend, a shop would charge a fortune to do that!
Sweet idea, it sure cleans up the first bend!
My current build up is my first turbo DIY build as well!
It is not something that too many people will consider doing!
Kudos to you!
Jim
Old May 8, 2008 | 11:18 PM
ls1_chevelle's Avatar
Kudos to you!
Jim
It sure does clean up the first bend!! I've posted in your threads. Really love the simplicity of it. I KNOW it will work!
DIY ftmfw hahaha
Old May 9, 2008 | 01:24 AM
7845's Avatar
actually the elbow is from pepboys. its 20 bucks i do beleive and is a decent solid 90*. not to flimsee
Old May 9, 2008 | 07:32 AM
hellbents10's Avatar
LS1Tech Sponsor
I too have welded v-band to factory manifolds 4 times now. Works awesome!!! Nice build ls1 chevelle.
Old May 9, 2008 | 07:48 AM
Firechikn's Avatar
I'm glad this thread came up. I just bought a 6"x 10" round k&n for my car. Going to tuck it behind the bumper. I was wondering if it would restrict me or not. Looks like I need a min. of 128" of filter and I'll have 187 or so.
Old May 9, 2008 | 10:21 AM
SPRAYED 01's Avatar
How bad do you think putting a 4 inch to 3inch reducer with a 3inch k&n would have? I have a 90 bend that reduces then the filter.
Old May 9, 2008 | 10:25 AM
RW99's Avatar
Would intake air filter restriction give you the same sort of symptoms that maxing out a turbo would? I have a T67 front mount on a 346 that doesn't like anything above 11 psi or so (0.96 exhaust A/R), and I've just assumed that this limitation was due to the turbo itself.
Old May 9, 2008 | 12:41 PM
tirefryin_s10's Avatar
Matt I run a big 4"rubber elbow on my turbo with a big K&N its joined together with a piece of 4" exhaust pipe and t bolt clamps.
Old May 9, 2008 | 01:59 PM
  #32
bud8fan's Avatar
i just got done ordering AEM #21-2259DK along with the 4" elbow and 6" piece of 4" tubing...thanks for the help...
Old May 9, 2008 | 05:58 PM
  #33
From where, what elbow did you order? got a part number.
Thanks for all of the help guys. Keep posting away if need be.
Old May 9, 2008 | 06:12 PM
  #34
Reject's Avatar
what are the demension's of that filter? i searched around but it only tells you about how awsome it flows and covers 99.4% of particals and just like that but no actual demensions
Old May 9, 2008 | 06:22 PM
  #35
if my research is correct its a 4" inlet, 8 inch base, 9" long tube
http://www.turbochargers.com/store/p...oducts_id/1442
Old May 9, 2008 | 06:27 PM
  #36
Reject's Avatar
thank you sir!
Old May 9, 2008 | 09:21 PM
  #37
bud8fan's Avatar
this was the cheapest i could find it...no shipping cost either:
http://www.performancecenter.com/pro...artnumber/4847
scroll down to find the size you want:
http://www.aempower.com/ViewCategory.aspx?CategoryID=93
Old May 9, 2008 | 09:28 PM
  #38
bud8fan's Avatar
this is where i found the 4" x 90*,clamps and 4" piece of tubing:
http://intakehoses.com/Merchant2/mer...gory_Code=9DEH
Old May 13, 2008 | 10:43 AM
  #39
sharp96ss's Avatar
looks similar.....
http://cgi.ebay.com/BLACK-Silicone-H...2em118Q2el1247
Old May 14, 2008 | 06:50 PM
  #40
Got an update for you guys. I bought just a standard 4" 90 silicone bend, 4 ply and a rubber 4" 90 aswell. Both fit, but I like the silicone better due to it matches all of my other couplers and I was able to trim it down some and get more clearance. I'm pretty sure no one will have issues fitting this piece, I wasn't even thinking about it when I designed the kit lol. Oh ya, ignore the filter.
