Proper blow off valve preload, turbo car
Old May 9, 2008 | 07:23 AM
homebuilt's Avatar
Default Proper blow off valve preload, turbo car
Does anyone know how to properly determine the proper blow off valve preload setting?
I can notice boost escaping though my blow off valve when I lightly accelerate. I have been progressively tightening the preload setting. I only had about one turn left on the bolt for the last adjustment. It might be bleeding some part throttle boost off but it is now chattering when I let off.
Any tips or recommendations would be appreciated.
Old May 9, 2008 | 11:05 AM
VUSS383's Avatar
If you have chatter back it off . It is normal to have some boost seepage at part throttle . You want your BOV to open as early as possible when backing off so you dont slow the spool of the turbo !
Old May 10, 2008 | 08:34 PM
homebuilt's Avatar
Ok thank you.
Old May 13, 2008 | 02:19 PM
homebuilt's Avatar
I backed the pre-load bolt off 3/4 turn and that was all it took to stop chattering. Thank you.
