Manifold gaskets - rtv or no?
Old May 12, 2008 | 08:08 PM
black98ws6ta's Avatar
Originally Posted by Mr.MartyStone
Then you need to look at what all the real high hp guys are doing (yes there are other motors besides ls motors). It is very common to not use header gaskets and just use RTV. When you start making real power you'll have problems with traditional gaskets...especially just carbon gaskets. At the bare minimum run an aluminum gasket.
Marty
Stock LS gaskets work very well, even at high hp/boost/backpressure. Everytime I see a aftermarket gasket used it is a problem.
Old May 12, 2008 | 10:23 PM
Mr.MartyStone's Avatar
LS exhaust gaskets arent traditional crappy gaskets. If the stock exhaust manifold gaskets are leaking under boost, then you need the flanges machined flat.
I'm not talking about running stock gaskets. And the turbo guys will have more of a problem than the blower guys...enjoy your supra though.
Marty
