what do you Guys Think
Old Aug 7, 2003 | 08:33 PM
Darren's Avatar
Default what do you Guys Think
I need to get this guys street car in the mid to high 10s and live to cruse on the street. This is the deal. Its a 98 SS camaro with a stock LS6 engine in it. I install a D1SC Procharger kit with 3.6 pulley it make about 7.5-8 psi of boost now. It also has slp header and a corsa exhaust. The fuel system has a vortech pump inline and the stock pump in the tank. Its got 42lb injectors and Ed write tuning. Its a M6 with a spec clutch the rear is a moser 12bolt with 3.73. The Car has some add weight with the stereo. We figure the car to be at about 3700lbs.
I have parts comming this is the plan. Dimond -8.6 piston, pro-mod rods, ported heads, 68 cc chambers, 9.1 compression. I what to run 15psi with decent fuel. I will be ordering the ati dampener and 8 rib belt. You can get it with a 7.5 or 6.75 size Blower drive pulley. This is where in need help getting close. I know All that can be predicted is impeller speed and cfm. But I know some of you guys out there have experimented with this. I will put what I think and you guys are welcome to give you thoughts.
Fuel injectors 50lbs
Pulley 7.5 Drive and 3.25 Drive
Cam 224/227 .563/.569 114 LSA
what do you guys reccomend for the fuel system?
Will all this be enough and be liveable?
Thanks Darren
