FAL-240 ?'s
Old May 18, 2008 | 10:59 PM
Frostbite's Avatar
Default FAL-240 ?'s
I am looking to clear up a bit of space to make room for the new turbo. Right now I have a stock radiator/fan setup with the radiator moved forward to the condensor location. So my questions are....
1) I would like to use stock wiring so the computer controls the fans, will the FAL's 19.5 amps overload the stock wiring/relay setup?
2) Will the fans fit with the radiator in the location that I have now? If not, will it work in the radiators stock location or what is required to make them work?
3) Jegs claims the FAL240's are good to 250hp. Will I have any problems cooling my setup? (Ls1 w/ 67mm)
Thanks
Chris
Old May 19, 2008 | 02:17 AM
Josh@KY-Turbo's Avatar
I use tham alot. They have cooled setups making well over 250hp. More like 750hp.
Old May 20, 2008 | 03:53 PM
Frostbite's Avatar
Thanks Josh, thats what I figured
Anyone know about the other ?'s
