Should i bump up the boost?
Old Jun 2, 2008 | 02:33 PM
black98ws6ta's Avatar
You will not be able to bolt it on if it is not an on center housing...it will take quite a bit of modification. You can also have a simple turbo kit and not leave tons of power on the table with a bad designed hotside. I'm just trying to help, I have watched people spend alot of money and time trying to get badly designed stuff to run right.
Old Jun 2, 2008 | 02:54 PM
SPRAYED 01's Avatar
I spoke to drturbo before i had ordered it. I had told him i was running a pte67 with a 4inch inlet,and .96 ar housing. He said it should be the same pyhsical size and should bolt right up.
I do hear what your saying on getting a better designed hot side. And i will with money allows but for right now i figure that this is the turbo im going to carry on to my next setup so why not get it now.
Old Jun 2, 2008 | 03:14 PM
Sounds like the fact that it is on center was left out....I'd double check with him.
Old Jun 2, 2008 | 03:37 PM
SPRAYED 01's Avatar
Thank you for the heads up.
Old Jun 2, 2008 | 05:17 PM
SPRAYED 01's Avatar
I got the car up in the air and it is an on center setup.
