98 pcm
Old May 28, 2008 | 04:09 PM
frcefed98's Avatar
I never had a problem running 2 bar SD on my 98 PCM? HPT has had 2 bar SD available for a while now.
J
Old Dec 29, 2008 | 10:51 AM
z28mccrory's Avatar
Sorry to dig this thread up from the dead...
Is there any way to use the 98 PCM and run a 2 bar map if i have EFI Live. I already own EFI Live so im kinda stuck...
Old Dec 29, 2008 | 11:31 AM
Frost's Avatar
You would have to re-pin the PCM connectors, run a later model PCM, and have a fuel-seg from an Express Van swapped in to make the fuel gauge work.
Other than that, there is HPT...
Old Dec 29, 2008 | 11:38 AM
98CamZ28's Avatar
Kinda similar question (not really ) I did a 98 to 99+ swap where I replaced the 98 engine harness to the newer one and replaced the pcm. I just rewired the connection points under the passenger side dash where the engine harness comes through. My car is tuned and runs good, but, what can I do about my fuel gauge (as it doesn't work). I was going to switch to a plastic 99+ tank and fuel pump but, I just saw you post something about a Van swap. And info that might be of use to me?
Thanks,
-=josh=-
Old Dec 29, 2008 | 11:50 AM
MECHAM's Avatar
i have hpt and will trade u for efi live.
it does all 98s and one other year 99, 00, 01...i dont remember which year tho...
you will need to purchase the 2bar sd tune if you wish to go that route...i think it was $99?
Old Dec 29, 2008 | 11:57 AM
z28mccrory's Avatar
The main reason i went with EFI Live to begin with is because of the COS5 which is the Nitrous Operating system (for use in my 418 car)
This sucks, lol... why cant EFI Live come out with a solution for 98 cars.
Old Dec 29, 2008 | 12:00 PM
z28mccrory's Avatar
If i run a larger like 85mm MAF can i get by with making more power? My goal is 500-550rwhp... thats as far as i want to push it for the time being.
Old Dec 29, 2008 | 12:43 PM
black98ws6ta's Avatar
You just need to have someone with hptuners tune the car 2 bar SD, lol. Running a larger maf does nothing as the g/sec limit is in the pcm. There are tons of ways around that also, but the tuning of choice is SD. Reply to my pm on LM?
Old Dec 29, 2008 | 12:50 PM
Frost's Avatar
Thanks,
-=josh=-
that's relevant to you too...
Old Dec 29, 2008 | 07:13 PM
RICE ETR's Avatar
Turbo Addict
I am still running the stock maf and '98 pcm...I max it out around 3,000rpms if not before....but I just spray a bunch of meth and watch my AFR's and don't worry about what the maf or pcm is thinking. It's not the right way or the safe way but it works.
And fwiw, Frost can almost make your car talk with his laptop and mad tuning skills.
Old Dec 29, 2008 | 07:40 PM
jomomma's Avatar
im hoping to not be at my limit. im running 13psi w/ my stock tuned pcm and maf.
Old Dec 29, 2008 | 08:12 PM
  #32
z28boy's Avatar
My car is a 98 with maf EPP tuned it and made over 500hp not sure what was involved. I didn't no you could sd tune 98s?
Old Dec 29, 2008 | 10:30 PM
  #33
sagres's Avatar
Hey steve (frost)I got my car running might have to pay you a visit to do a 2 bar setup. PM your number (Lost your# in old phone) bud Ill give you a call. See whats involved. Im trackiing a intermidment prob with my speedometer and tach right now and cursing god for it. Im on a maf tune right now 602rwhp and 712tq (14lbs)thru a 4l80e(standalone computer).
Old Dec 29, 2008 | 10:40 PM
  #34
ddnspider's Avatar
98 pcm here tuned with ls1edit....stock maf/map still on it.i believe it just maxes out the maf and runs off the VE table.
Old Dec 29, 2008 | 11:43 PM
  #35
Frost's Avatar
You passed the MAF's max back around 7 psi
2bar OS is in your future too...
