What is a good ring set for a boosted street engine ?
Using Wiseco -3.2cc piston's , 3.905'' .
Piston's require : 1/16 , 1/16 , 3 mm .
Heard the same about mahle from mahle when I re-ringed mine a couple months ago. Told them I was going to boost up to 14 lbs (700-800 hp) on this setup and they said I'd be good. Just make sure you go with the manufacturers recommended ring gap for FI
