Power falling off above 4psi
Old Jun 9, 2008 | 08:56 PM
KnightmareLS1's Avatar
Your car sucks!! J/K I think you need new springs but hopefully the intercooler will help.
Old Jun 9, 2008 | 09:01 PM
NYSS Guy's Avatar
If you were trying to run 8 psi without the intercooler, your IAT's were likely way too high. The computer would be pulling gobs of timing to keep the motor together. You would have been better off running 5 psi, and running the correct amount of timing at that boost level until you got the IC...kind of a moot point now.
Old Jun 9, 2008 | 09:35 PM
autosay97's Avatar
Depending on whether the car is a stick or auto pulling timing will sometimes increase boost. We pull timing in stick cars in lower rpms to decrease lag.
Old Jun 10, 2008 | 06:41 AM
Silver_TransAm's Avatar
Originally Posted by autosay97
There is a reason for you not hitting 8 psi, re check all your hot side piping. You should be seeing 8 psi period, I bet you have a big hotside leak somewhere. Check your wastegate valve to seat, may need to be lapped in. Also, what a/r on the turbo?
I am hitting 8psi at the end of first and from then on. a/r cold side is .60 and .96 exhaust side.
Old Jun 10, 2008 | 06:45 AM
Originally Posted by SP Motorsports
check intake air temps,but ore importantly check how much timing you have in it when it goes deep in the 10s ,might just be blowing out the spark to rich to little timing
I think you may be onto something here. Air temps do get pretty damn hot 160 plus. As for timing it may have very little do the time tuner spent on it (i was in a hurry to get back to georgia from texas) . My tuner just set it real safe till I had time to come back.
Old Jun 10, 2008 | 06:48 AM
Intercooler is going on this week. It is from CXracing and its demensions are 31x12x3 This should do the trick I hope.
Also where can I get some tr8 plugs?
Old Jun 10, 2008 | 06:49 AM
It better I cant stand losing to you!
Old Jun 14, 2008 | 10:09 AM
dredoggy's Avatar
you may want to change your a/r to .81 it will spool quicker but that is not your problem more than likely its 2 things valve springs and high iats. change these and you should be able to run 8# all day long
Old Jun 14, 2008 | 08:17 PM
lt170chevelle's Avatar
i was running 8lbs without an intercooler initially and since my intercooler install i was able to add 2 degrees of advance and iat was much better.power increase was also very noticable. i am still running stock springs and they are getting murdered with the boost. tons of bottomend but topend is bad with the stock springs. i would definitely recommend some springs. also have i have that intercooler and works great
Old Jun 14, 2008 | 08:20 PM
Cool. Glad to know that intercooler wrks great, just trying to find the time to install the intercooler.
Old Jun 14, 2008 | 11:19 PM
SPRAYED 01's Avatar
Is this a new setup for you? What im getting at is has this problem been around since day one or has the setup working for you in the past?
If this is a new setup then check one really easy thing. Your turbo inlet setup. Is it just a straight filter right at the inlet or do you possibly have a silicon elbow first. If so it could be sucking shut after 4lbs. I had this problem when i first started off the the crazy world of FI.
Alex
Old Jun 15, 2008 | 11:50 AM
  #32
Alex
Has the original sts design, metal elbow then filter. Noway that is hurting it. Makes 8psi, its just the power kinda stops building after 4psi.
Old Jun 23, 2008 | 10:21 PM
  #33
dredoggy's Avatar
hows your fuel system? stock? and is that intercooler done yet?
Old Jun 23, 2008 | 10:41 PM
  #34
Fuel system consists of 46lb injectors and a walbro 255l pump. Yes the intercooler is done as of today! Had the charge piping come off twice, but now is good. I am only seeing 4 to5 psi now with the intercooler, where as before I saw 7 to 8 psi. Need to reference the wastegate after the intercooler or get boost controller. Post some pics soon, camera be stupid.
Old Jul 5, 2008 | 09:54 PM
  #35
dredoggy's Avatar
camera still stupid?
Old Jul 5, 2008 | 10:07 PM
  #36
http://s293.photobucket.com/albums/mm52/slink410/
all pics i have for now. Enjoy.
Old Jul 5, 2008 | 10:12 PM
  #37
Car is running pretty strong now. Just waiting on my boost controller to come in. I also have an appointment to get my car retuned for 8psi now that I can keep the IAT's in check. Got a sweet new toy too, the Interceptor gauge, IT ROCKS!!!
Old Jul 7, 2008 | 08:40 PM
  #38
dredoggy's Avatar
nice work on th intercooler!! let us know on the #'s at 8# when you retune
Old Jul 7, 2008 | 09:08 PM
  #39
sure will. Hoping for 550 or so. Trying to get some 6.0 heads for it before the tune so I can run like 10-12psi.
Old Jul 8, 2008 | 07:48 AM
  #40
dredoggy's Avatar
sweet. you could also get there with some meth injection! or e85
