Pics of OFI radiator and fan setup?
Old Jun 13, 2008 | 02:32 PM
94m6Z28's Avatar
Originally Posted by cablebandit
it may just be me but the a/c will not work with the condenser BEHIND the radiator...the heat from the rad shot up the a/c pressure and mine would cycle the compressor constantly on/off once coolant temps got to190
what did you do to fix this?
one of the main reason i got this kit was the front mounted ability to "keep" the AC in its "stock" location
Old Jun 13, 2008 | 04:15 PM
DanZ28's Avatar
Originally Posted by 94m6Z28
Danz28, where did u get that expantion tank or the PN for it? ive given up on my OFI unit its just not made ti fit with eas and keeping the batterie in place. it sucks
It's on Canton's website http://www.cantonracingproducts.com/...ion_tanks.html #80-200
Old Jun 13, 2008 | 08:24 PM
cablebandit's Avatar
See what Joel tells you first as he still says it keeps a/c...then I will chime in.
Old Jul 4, 2008 | 09:09 PM
JerikSS's Avatar
Has anyone had issues with the ofi kit with the condensor in the back of the radiator?
Old Jul 5, 2008 | 01:09 AM
94m6Z28's Avatar
ill let you know in a couple of weeks when i get the system charged. one issue i can alreayd tell you about is the small line being an *** hair away from the upper rad support so getting a connector on there to fill the system is going to be a P.I.A
