where do the vacume lines go.........
Old Aug 15, 2003 | 06:46 PM
Assassin's Avatar
Default where do the vacume lines go.........
that are on the top and the side of the wastegate?
Old Aug 16, 2003 | 12:00 PM
y2khawk's Avatar
Default Re: where do the vacume lines go.........
Assuming you have an external wastegate, IE deltagate, racegate, HKS, Tial, etc....
The bottom hole, probably on the side of the gate, goes to "pressure" Ideally you tie the bottom port to the turbo outlet itself. You can go to the manifold, but you can get into compressor surge at lighter throttle. But, it does make up for any intake/intercooler pressure drops that way.
The top port is either open to atmosphere, or connected to a manual boost controller. Don't just plug the hole, can cause the gate to respond slowly or not at all.
Old Aug 21, 2003 | 03:48 AM
Assassin's Avatar
now, what if you didnt connect the outlet of the waste gate to exhaust and just let it blwo right out, that would give it an extremely loud turbo sound right?
