Day 1 Build Ebay Kit
Old Jun 22, 2008 | 12:03 PM
rickou812's Avatar
Signing up
Old Jun 22, 2008 | 01:38 PM
BlazinT/A's Avatar
i check this thread like ever ten minutes im so excited
Old Jun 22, 2008 | 08:34 PM
Monello's Avatar
At my buddies house, had to drop him off. Will be posting the pics in the next 30 mins.
Basically got the passenger side header mounted, crossover. Wasnt able to mount the driver side yet because one of the holes didnt line up. Need to drill it out a bit more.
Got the intercooler mounted, with piping to Intake and almost to where the turbo will be mounted.
brb =)
Old Jun 22, 2008 | 09:07 PM
4SFEDZ's Avatar
brb =)
its been 33 mins hurry up!!! lol!
Old Jun 22, 2008 | 09:26 PM
Elcaballoloco's Avatar
Subscribing also...
Old Jun 22, 2008 | 09:55 PM
Monello's Avatar
Here are the pics as promised!
I worked on the hot parts mostly. Then Mike wanted some help on getting the cold pipes mounted right, so we both focused on the cold pipes and the routing seems like it will work great.
Here are the pipes wrapped and sprayed.
My buddy Mike looking for ways to mount the cold pipe.
Passenger Side header mounted.
The Passenger side header was really close to the trans housing. Had to trim it a bit to get the V-Band clamp to go over it.
Bumper and Foam removed.
Crossover pipe mounted.
Mike drilling the holes for the intercooler.
Intercooler mounted. Mounted it with 2 bolts and its solid, doesnt move at all. We still added 1 more strap to the front. We used header bolts, they are a perfect fit for the intercooler =).
Old Jun 22, 2008 | 10:00 PM
Websy21's Avatar
What about the oil drain for the turbo, you need to tap the pan and have to drop the k member to do it. Its really fun, jsut did it last week.
Old Jun 22, 2008 | 10:08 PM
Monello's Avatar
Going to tap it while on the car =)
Everyone does it lol.
Old Jun 22, 2008 | 10:13 PM
Reject's Avatar
i droped mine to tap it and cought alot of little shavings. then had to remove it cuss it was to close to the starter. so i droped it again but this time with the bmr k-member in place..... it was super easy like litterly about 30 minutes to take it out including removing the starter and alternator and all the little bolts and wires in the way
Old Jun 22, 2008 | 10:16 PM
1CAMWNDR's Avatar
Nice. Can't wait for the next set of pics!
Old Jun 22, 2008 | 10:29 PM
BLWN1's Avatar
good deal, looking good.
Old Jun 22, 2008 | 11:26 PM
  #32
Frost's Avatar
given the fact that the kit causes some cooling issues because of the removal of the stock fans, I wouldn't block up my radiator like that with the IC.
Old Jun 22, 2008 | 11:29 PM
  #33
frcefed98's Avatar
looks good so far. Hope the intercooler placement doesn't make the car run hot.
J
Old Jun 22, 2008 | 11:43 PM
  #34
Websy21's Avatar
I am agreeing with frost and frcefed
Old Jun 22, 2008 | 11:59 PM
  #35
Hennytime's Avatar
looks nice, i would also go with the traditional front mounting of the ic
Old Jun 23, 2008 | 12:13 AM
  #36
GrandmasterCow's Avatar
i would have to agree also with the above posters.
Old Jun 23, 2008 | 09:10 AM
  #37
Monello's Avatar
We will see how the temps are with the IC mounted like that. The problem is, I REALLY dont want to lose the bird license plate, and foglights.
Im going to give this a shot. If it doesnt work, I will just mount it the other way. The pipes wont have to be moved at all which is a good thing.
Frcefed, do you remember if any of the Hi-Flo guys have problems with cooling? I know that this is how their IC is mounted.
Old Jun 23, 2008 | 10:34 AM
  #38
BlazinT/A's Avatar
did you have to do any work to get the header bolts to line up?
Old Jun 23, 2008 | 10:49 AM
  #39
Monello's Avatar
Yea the driver side header hole needs to be drilled out more.
Old Jun 23, 2008 | 12:21 PM
  #40
BlazinT/A's Avatar
congrats it looks very nice, what are you going to do for engine managment?
