D1SC rebuild cost??
Old Jun 24, 2008 | 03:25 PM
bluehawk2's Avatar
Default D1SC rebuild cost??
I have a used Procharger kit on my car and I want to have it sent to Procharger for a rebuild. Does anyone know how much it costs to have a D1SC rebuilt?
Would it be cheaper to send it to Bob at EPP or just deal with Procharger directly?
thanks
Old Jun 24, 2008 | 05:27 PM
1dirtyZ's Avatar
it depends on what needs to be changed . i had my F1-R rebuilt ( it spun the impeller on the shaft) for $1500 !
Old Jun 25, 2008 | 08:56 AM
BLNLS1/RX7's Avatar
thanks
You need to contact Bob at Exotic Performance Plus.They can give you the best advice on ProChargers.
Old Jun 25, 2008 | 11:31 AM
One Bad Z's Avatar
I think procharger charges $75 just to inspect the blower. And if something is bad that 75 goes towards the repairs.
$1200 is the quote i was given.
Old Jun 25, 2008 | 12:47 PM
bluehawk2's Avatar
Mine is doing good, it is just getting a little oil from the head unit into the piping.
Old Jun 25, 2008 | 05:18 PM
1dirtyZ's Avatar
just run it , consider that leak as your air to oil cooler - you just haven't gotten to the part where the oil goes back into the blower
Old Jun 25, 2008 | 06:09 PM
EPP's Avatar
EPP
Thumbs up
thanks
I can save you some money, I'll check on the prices for you. Bob
Old Jul 1, 2008 | 02:04 PM
bluehawk2's Avatar
Thanks, I will give you a call when I am ready to pull it off for the inspection.
Old Jul 1, 2008 | 04:21 PM
STALL UP's Avatar
1700$ to upgrade my p1sc-1 to a d1sc after sucking water through it.
Old Jul 5, 2008 | 07:31 AM
EPP's Avatar
EPP
I can typically save you $100.00 on the rebuild. Bob
Old Jul 5, 2008 | 07:40 AM
WS6Drop's Avatar
Can we send the headunit to you to check the clocking as well or should we call procharger for that.
