APS TT 92/92, Vic JR or GM performance
Old Jul 8, 2008 | 05:49 AM
98_twinturbo's Avatar
Default APS TT 92/92, Vic JR or GM performance
What is the best intake manifold fast 92/92 or Vic JR or Gm performance in APS TT?
Old Jul 8, 2008 | 07:24 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Personally I feel that the FAST setup for the cost does not justify the gains on FI systems. I think the Vic Jr setup is the better route even though it might require some cowl modification to get things to fit.
Keith
Old Jul 8, 2008 | 09:29 AM
MY99TAWS6's Avatar
Bang for the buck likely ls6 intake manifold. Fast 90 or 92 work well in fi up to 20psi or so anyway. On afr website they have a link to two 1000 engine hp builds that use fast 90 /90 combos. On the one they did use a carb type intake intitally but in the article they said the fast intake made more power but didn't give numbers.
I already have fast 90/90 combo so going to be using it on my build.Won't likely have any numbers until sept/october or next spring though.And also as you can see in sig using a 408 with afr heads,ling cam with 1.8 rockers.
Old Jul 8, 2008 | 01:36 PM
99 black ss sj's Avatar
also interested on this subject bump
Old Jul 8, 2008 | 02:06 PM
DanDan's Avatar
I just picked up a 92MM Combo for my APS set up. The price was right so i jumped. This subject has been brought up a lot just so you know. I wouldnt worry to much about it...
Old Jul 8, 2008 | 02:36 PM
52172's Avatar
get a used ls6 for cheap and port your TB and you can make over 1000 rwhp with the setup without any issues. Why not?
Old Jul 8, 2008 | 03:52 PM
deadmanTA's Avatar
If you want the look of the carb style then Vic jr (that's what I did). For ease, price, and funtion then LS6 all the way.
Old Jul 8, 2008 | 11:20 PM
qqwqeqwrqwqtq's Avatar
You will max out the APS system long before an LS6 intake and stock throttle body become a restriction.
Old Jul 8, 2008 | 11:53 PM
52172's Avatar
Looks like we made up your mind for you now DO IT..................
