Uh, so..which charger..which cam?
Old Jul 11, 2008 | 09:32 AM
jbusmc1986's Avatar
if you are dead set on a maggie.... you can use a ms4 cam.... it has been tried on here before, with great success and the guy made 59x rwhp on I believe 7-9 psi or so. This cam would only work with a positive displacement blower, as it bleeds off some of the power down on the low end, which helps with traction. And on the top end it makes power like a ****.
Old Jul 11, 2008 | 09:37 AM
tator98ta's Avatar
I'd need the power up top. The kids around here are in love with roll racing. Thanks for all the replies guys. It seems there are multiple choices i could go with.
Old Jul 11, 2008 | 09:56 AM
jbusmc1986's Avatar
also keep in mind, that is the max that you will ever see outta the maggie. The only way to really start seeing more power is to spray. Which woul kill your bottom end, but if you are content with 600 hp then you will be fine.
