NGK TR8 vs. gasketed plug
Old Jul 15, 2008 | 11:22 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default NGK TR8 vs. gasketed plug
The plugs in question:
Stock no. 7317, R5724-8
Stock no. 7173, R5672A-8
The second one is gasketed, are these plugs the same heat range. MMouse, what plugs are you running, gasketed 3911's?
I'm runnnig Allpro heads and gasketed plugs were suggested a long time ago and I still run them, but the other plugs don't look like they would really protrude more into the combustion chamber.
Old Jul 15, 2008 | 11:30 AM
onfire's Avatar
Coal Mining Director
7317 is a stock type head plug with the stock 0.708" reach. Any after market head that is designed for a stock reach tapered seat plug can use that series.
7173 is a 0.750" reach non tapered seat. It's up to the head design to see if it matches that plug. "Should" be the same heat range....it's just a head design question.
Old Jul 15, 2008 | 12:05 PM
MIGHTYMOUSE's Avatar
the 7173 is a full tip NGK euivalent of the autolite racing 3911 that w2w reccomended
the -8 at the end of the manufacturers number R5672A-8 indicates heat range
Old Jul 15, 2008 | 12:34 PM
stevieturbo's Avatar
Installed height of gasket/non gasket plugs is negligable. They are basically the same in the chamber.
Ive tried a few different plugs in my 853, Edelbrock, and now TFS heads ( TR6 and various gasketed ) I posted the pics up ages ago here somewhere.
These heads are intended for taper plugs, Ive pretty much always run gasketed plugs, as virtually no cars in Europe/UK use taper seats, so its hassle to get them.
Currently using BKR8IEX as reccommended by NGK. So far no complaints.
Old Jul 15, 2008 | 12:48 PM
LS1Tech Co-Founder
So Dave you are running gasketed plugs?
Old Jul 15, 2008 | 04:52 PM
Fireball's Avatar
I'm also running the AR3911 which is a gasket plug.
Old Jul 15, 2008 | 04:55 PM
LS1Tech Co-Founder
Brian are you running Allpros?
Old Jul 15, 2008 | 08:36 PM
Fireball's Avatar
etps...but harlan told me 2 years ago to run a gasketed plug, even though the etps have a tapered seat...
 Michael S. Palmer
Old Jul 15, 2008 | 08:54 PM
LASTLS1's Avatar
6 Second Club Moderator
I run the tapered seat.
Old Jul 17, 2008 | 07:11 PM
LS1Tech Co-Founder
So only AllPro's require a tapered plug?
Old Jul 17, 2008 | 08:15 PM
Fireball's Avatar
I thought allpros required gasket seats?
Old Jul 18, 2008 | 01:37 PM
LS1Tech Co-Founder
Yup....
Old Jul 28, 2008 | 02:09 PM
Superado's Avatar
11 Second Truck Club
another -8 heat range NGK:
stock #4554
NGK #R5671A-8
gasketed, non-projected
Old Jul 28, 2008 | 03:41 PM
y2khawk's Avatar
not all ET's have a taper seat.
Gasket into taper ok, taper into gasket = fubar'd first couple threads.
check the heads first.
