ls6 cam and some boost?
Old Jul 24, 2008 | 01:02 AM
whitew01ws6's Avatar
Default ls6 cam and some boost?
is it worth it to throw a ls6 cam out of a 07 CTS-V in my car with a turbo set up and is this ls6 cam any different than for say a zo6 cam from a C5
i cant seem to find any specs on either cam so i dont even know what size she is.. and what kind of gains would that came make in u guys opinions?
thanks
Old Jul 24, 2008 | 01:03 AM
AAAAHHH WTF WHY IS THERE SPAM ON HERE.... spam sucks its like a yeast infection in a can
trans2000am's Avatar
id just go custome spec from a vendor
Old Jul 24, 2008 | 01:14 AM
jason02Z's Avatar
u pretty much have the same cam in the ls2 cts-v
not bein nasty but that didnt give me any insight.... this is a budget thing and i can get the cam cheap so...yeah
Old Jul 24, 2008 | 01:44 AM
cheap isnt always good, id do it once and do it right. cam install isnt any fun to install at times specially when motor is in the car. And how cheap is the cam ur getting if u mind saying?
Old Jul 24, 2008 | 01:55 AM
150 with the springs
Old Jul 24, 2008 | 02:08 AM
what kinda springs?lift? zo6 cam is almost the same specs as lingenfilters gt-7 cam.
 Michael S. Palmer
Old Jul 24, 2008 | 02:15 AM
they are apparently the stock springs from the 07 ctsv and stock cam should i go with it, im not expecting huge HP gain maybe 20 - 30 wheel would be nice what do ya think i should do
Old Jul 24, 2008 | 07:34 AM
forcd ind's Avatar
acc. to the gm book, the 01 ls6 cam was 207/217, .525 lift, the 02-04 ls6 cam was 204/218, .550 lift
not really sure what they did in 07, a guy in the parts dept should be able to do specs, if he wants
there should be a part # on the cam, that will help zero in on the specs
Old Jul 24, 2008 | 08:01 AM
xxrillixx's Avatar
your missing alot of key info... what kind of car is it? Boost... tc or sc? any other mods? Stock cam now? How many psi do you want?
I did a ls6 cam w/ my 99 camaro turbo setup, id does well. Its not the best out there, but for a cheaper build its nice. I hope you already have aftermarket springs... or are atleast planning on them.
I was told there is a difference between the pre 01 and 02 and after ls6 cams, but not sure if thats true (or even if it was those years). And with the newer ones something had to be done to make it work. Its been a while since ive looked into it, so i dont remember the details.
If you do decide to do it, you should really do the oil pump & timing chain. Dont skimp on that stuff. Your in there, you might as well do it assuming you havent already.
Old Jul 24, 2008 | 10:09 AM
98Z28MASS's Avatar
You probably want at least comp 918's or a dual value spring (Patriot Duals are really good), so basically it would be $150 for the cam. Im not sure if you will see 30 rwhp increase with the LS6 cam, but if thats the route you want to go its better than the stocker. As others have suggested id get a custom grind from one of the sponsors and if you dont mind a little lope/choppy idle id get something in the 22X/22X range. JMO and good luck with the build!
