2 much or 2 little oil???
Old Jul 30, 2008 | 01:22 AM
rudyzturbota's Avatar
Default 2 much or 2 little oil???
how much oil should you have running though your turbo? ive got mine located where the battery use to be an i was wondering if im getting enough or to much oil. is there a fitting i can use that will allow the right amount of oil in, or am i thinking to much into this??do i need a pump or is there enough pressure to feed the turbo its oil?? i did a search on this an couldnt find anything, all help is welcome. what kind of fittings do you guys use?
Old Jul 30, 2008 | 08:15 AM
DMH Fabrication's Avatar
You do not need a separate pump. The engine can feed the turbo fine. You can run a restrictor on your inlet fitting to control how much oil the turbo gets. You may try searching the FI section for oil restrictor since there have been threads in the past on this topic or you can always call the company that built your turbo and ask what size restrictor they recommend on the inlet.
