oil lines for a turbo set up
Old Aug 27, 2003 | 04:22 PM
mkoch1's Avatar
Default oil lines for a turbo set up
Is there anywhere on the engine I can run the return oil lines from the turbo to or do I have to tap the oil pan?
Where is the best/easiest place to hook up the oil pressue line going into the turbo. Right above the oil filter there is a block off plate. If I remove that plate will that be pressurized.
mark
Old Aug 27, 2003 | 04:43 PM
RICE ETR's Avatar
Turbo Addict
Default Re: oil lines for a turbo set up
yes.. the QMP and TurboTech kit use the port above the oil filter.... just drill out the hole to whatever dia you feel is sufficient for oil your turbo/s... i think with a stock oil pump QMP runs a .050"-.070" hole... i think... MM and others?
And the return lines... well QMP and TT have it on the front bottom driver side of the oil pan.. see here: http://community.webshots.com/user/mightym0use
I think CAS put theirs on the side above the oil level sensor... do a search
Old Aug 27, 2003 | 05:23 PM
red ws6 99's Avatar
Are you using gravity drain or pumping back to the pan. If you are pumping back to the pan you can use the oil level sensor port or even the drain port.
Gary
Old Aug 27, 2003 | 07:04 PM
mkoch1's Avatar
I figured I had to tap the oil, just didn't want to belive it since I just bolted up the oil pan last weekend. O well I guess it's coming back off. The oil coming out of the turbo will be gravity feed, not pumped.
mark
