is a single 88 to big for a 408?
Old Aug 4, 2008 | 03:30 PM
rubbersdown's Avatar
Default is a single 88 to big for a 408?
Is a single 88 to big for a 408? I am thinking of either running twin 68's or a single 88. Its 99% street driven so I think twins would spool way faster but is it worth the extra $? I can get a gt4788 for around $1200 or I can get twin tc68's for around $1700, not to mention the extra Wg, flange, Dp, and all that fun stuff.
Old Aug 4, 2008 | 03:32 PM
hellbents10's Avatar
LS1Tech Sponsor
A 88 is defiantly not to big for a 408. Depending on the power you want to make you could spin some decent sized twins too.
Old Aug 4, 2008 | 04:22 PM
W8N2SQZ's Avatar
One good thing about the twin set up is usually better spool time and a higher potential for more power.
I had a single 76gts on my 347 and now I have twin 66's. I am waiting on a turbo to come back from Tnetics and than I will get it running.
My TC66's are T4 flange and with the 38mm gates I have, I can sell the 66's and go all they way to twin 78's down the road. It would take a larger single than a 4788 as well as changing the hot parts to get the power of twin 78's over 1 GT55 or something similar.
Just my .02
Glenn
Old Aug 4, 2008 | 04:26 PM
I am looking for around 800rwhp
Old Aug 4, 2008 | 04:27 PM
theblur98ss's Avatar
Alot of us are running 91's on 408's. An 88 should be a good size for a 408 with 1000hp potential
Old Aug 4, 2008 | 04:40 PM
LS1Tech Sponsor
4788 would be just fine for 800whp.
Old Aug 4, 2008 | 04:42 PM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
im running a 94 on a 370.
Old Aug 4, 2008 | 04:50 PM
Shawn @ VA Speed's Avatar
4788 will be fine,just make sure you get the correct turbine housing
 Michael S. Palmer
Old Aug 4, 2008 | 04:53 PM
DrTurbo's Avatar
LS1TECH Sponsor
If you can wait......Budget Garrett units are coming as well.
Old Aug 4, 2008 | 05:01 PM
1969mach1's Avatar
I'm new to turbos, but the 88mm is not too big. As for a Twin set up being better than a single, I don't know... I have seen some Fast single turbo cars that spool up very fast.
I'm building a single 66mm system for a stock 346 LS1. I'm looking for around 500-550rwhp.
But, good luck with the build and post up some pics if you can we all would love to see.
Old Aug 4, 2008 | 05:11 PM
But do you guys think an 88mm will have a descent spool time and descent street manners? and recomendations on an a/r, and trim?
Old Aug 4, 2008 | 05:25 PM
DrTurbo's Avatar
LS1TECH Sponsor
With the right 88 yes it will work. A/R on a 1000rwhp car needs to be enough to meet the turbine side lbs/min to feed 1000rwhp. Typically around ~55lbs/min
Old Aug 4, 2008 | 07:08 PM
DrTurbo's Avatar
LS1TECH Sponsor
Originally Posted by BlueMonza
Budget turbo's? That got my attention. More info please.
We are working on them now...... Hope to have some prices soon. They will range from 70-88mm range.
Old Aug 10, 2008 | 09:24 PM
bigd98's Avatar
no i dont think so!!
Old Aug 10, 2008 | 11:19 PM
71 chevy's Avatar
just doing some basic calculations looks like you want something that can handle 75lbs/min at around 2.2 pressure ratio.
an 80 mm will get you into boost faster and more than handle your goals.
Old Aug 11, 2008 | 12:24 AM
VENGEANCE's Avatar
Ill be running a 98mm on my six speed 408... so no.
Old Aug 11, 2008 | 02:21 AM
71 chevy's Avatar
how much boost do you plan to run, and how much NA power will it be making?
Old Aug 11, 2008 | 12:25 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have a friend with a 408ci + GT47-88 and he made 920rwhp on a load dyno, good stuff. I think twin 66's are very cool too.
