ATI Superdamper gap between pieces
Old Aug 9, 2008 | 12:24 PM
Aster's Avatar
Default ATI Superdamper gap between pieces
I just received my ATI Super Damper (917264) and the instructions aren't all that great in it. Anyway trying to put it together I got the hub into the accessory shell ok and that sits flush.
The A/C pulley center section sticks out .54" from the pulley and looks like this part is supposed to sit into the space between the hub and the accessory pulley.
When I try and put then together though there is a .12" gap between the two pulleys, is this normal? I have attached a couple images to illustrate the issue.
Thanks for your help.
Attached Thumbnails ATI Superdamper gap between pieces-imag0014.jpg   ATI Superdamper gap between pieces-gap1.jpg   ATI Superdamper gap between pieces-gap2.jpg
Old Aug 11, 2008 | 09:13 AM
Aster's Avatar
Just as a note, in case anyone else ever has the same question. I spoke with ATI this morning and they did confirm there is supposed t be a gap there. I had just wanted to be sure before I tried mounting this thing up.
Old Aug 11, 2008 | 09:20 AM
ls1290's Avatar
Dumb Ass Vette Moderator
On my C5 8-rib setup, there was a gap between the two. Of course that was only a test fit to see how the two went together. I ended up ditching the whole AC system.
Keith
Old Feb 24, 2013 | 08:15 PM
sweet99ss's Avatar
bumping a 5 year old thread. There should be a gap on the f-body ati balancer 918853 also right?
