when does boost hit?
Old Aug 11, 2008 | 11:47 AM
lt170chevelle's Avatar
Default when does boost hit?
well i am redoing my tune and got to thinking..does my motor see any boost under 90kpa? I know it doesnt but would it. basically am trying to find out if i need to pull any timing or give any more fuel under 100 kpa? I was thinking of just adjusting 90+kpa just for safe measure.What do you think?
Old Aug 11, 2008 | 01:30 PM
Schantin's Avatar
You're not making boost at 90kPA, cause that means you're pumming vacuum. 100kPA i atmospheric pressure, and then it goes into positive boost frm there. 5PSI is about 135kPA and 210kPA is betweeen 14-15PSI.
What you need to answer for timing and fueling is how fast can the engine get into these #'s? A turbo will make some pressure even at cruise (you'll see it as reduced vacuum). So, you can be cruising at 2KRPM and have a MAP value of 70-80kPA which just doesn't happen NA. You need to add fuel/adjust timing accordingly across the board from 2KRPM up to account for this added pressure.
If you're using HP Tuners, just drive the car around/log it and set the fuel via the Ve Table. Set the "part boost (to 110kPA to around 12.0) and the WOT PE above 110kPA to 11.0-11.5 (depending what you're comfy with.) I'd dumb down the timing above 65grams/m3 and go from there. Should still have a "hump" in the Ve table showing higher numbers in the 4000-48000RPM range, as this is where the engine is making the most torque. It'll lean out a percent or two from 5K to redline.
Old Aug 12, 2008 | 01:58 PM
dam so my assumption wasnt right...that makes allotta sense...
Old Aug 12, 2008 | 03:23 PM
1320's Avatar
I agree, but one thing to remeber is if its 6 speed car or has a really tight convertor, you may want to reduce the pe requirements, to get pe to come in at such low rpm and throttle if its making boost quick.
Or go speed density.....
Doesnt the zo6 ve table go 99 or 100 at about 6000? I never thought about it before , but I think its a bit lower at the torque peak.
