highest fuel pressure
Old Aug 13, 2008 | 02:43 PM
cjg454ss's Avatar
Default highest fuel pressure
what is the highest you can regulate fuel pressure under boost,. twin walbros and 60 lbs injectors. if i referance the regulater how high can you go. 80psi, 85psi? thanks
Old Aug 13, 2008 | 03:08 PM
veee8's Avatar
The 255 lph hp walbros start to drop flow above 70 psi.
Old Aug 13, 2008 | 09:22 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
More pressure makes up for a lack of injector, but reduces pump output.
I generally recommend that starting w/ 58psi, boost reference to a max of 75psi.
Above this pressure or say 850rwhp, I would consider bigger injectors at lower pressure for best results. With large low impedance injectors, I would start with 43psi base pressure for best results.
Old Aug 14, 2008 | 12:35 AM
qqwqeqwrqwqtq's Avatar
I've run 5 bar base pressure with twin walbros and 60lb injectors with no problems. Have not tried higher.
Old Aug 14, 2008 | 08:39 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Also remember that the more pressure the pump(s) produce, the higher the temperature of the fuel and pump(s) will get. Both are not good as the high fuel temps can lead to detonation and high pump(s) temps can result in shortened life.
Keith
