Who's had the biggest ???
but the valve failing came something else
whenever i did this type of stuff 427 kept telling me it was the fuel until i finally started listening. i kinda listen now anyways.
I would suggest for something like that you run straight 110 at least.
I've run similar mph 144-145 with YSi and turbo, and both instances I was running about 19 degrees of timing plus race gas. YSi was 18 psi and 680rwhp thru a th400.
I'm driving around on 15 psi on pump gas, feels like high 130's, maybe maybe 140mph but if I ran the standing mile I'd run straight 110.
My timing for the most part has always been up around 26deg with meth, hence Ive left it there.
When I was running 148-149mph, it was at 26deg for most of that year ( 2006 ), with barely a single problem all year. 2007, and now 2008 have been more problematic.
This year, on dyno at start of year, one of the few times Ive managed to get to one.....we set the timing at around 18degrees, this on straight pump fuel only. But we were having missfires, due to weak spark ( not on LS1 coils ). Simply couldnt try the 50/50 I intended using at that time due to crap spark.
Im back up around 80/20 meth/water now.
I rectified that and another few problems, and the car finally revved properly. 7300rpm wasnt a problem now.
When I started using meth again, I kept increasing timing back to where I was, and it did seem to improve traps a little....probably not enough passes for any definative results though. Traps were still down on my bests of over a year and a half ago.
Car felt way better....just obviously wasnt making the same power for some reason ???
Generally speaking, I have never had head gasket problems. The only times Ive had to swap gaskets, are due to detonation incidents. First one the meth system failed due to an unrelated wiring problem.
So that failure was to be expected. It was more a lifting event.
This failure has been the 2nd...and rather catastrophic. So I dont think I need better studs or gaskets just yet ?? or indeed the 6 bolts...which would necessitate a full head/block swap !!!!
That is a no go on cost alone.
Weber have some great deals on short motors at the minute.....but still more than I'd like to have to spend.
My cheapest motor fix, is as above. Block, pistons/rings and the valley cover and lifter trays, for the basic swap.
Although they do have FS, a 427 rotating assembly, which would require a block for decent money. One of their shop guys is selling it, if its still available. it was in the Sponsors section recently.
Id be concerned that a 427 might reduce HG life though, due to the much larger bore ??
I think a simple 402 is the way to go.
Obviously the LS2 requires a couple of different head studs over the LS6 block...hence may as well buy a new set. Ive had my existing ones for over 3 years now anyway.
Im just raging how bad Ive f**ked the heads during this !!!!
Also shocked to see how badly melted piston no 8 is compared to the rest !!.
Left hand bank will be interesting !!!
And to boot, I dropped my bloody digital camera and cracked the LCD...so now its broke !!!
What a weekend
Ive pulled both heads, and fortunately the LHS looks to be in good enough order. Its lost a tiny bit of alu between the valve seats on cyls 1 and 7, but otherwise, ok.
Pistons and bores even look fine from above.
Made a slight error before though, got slightly disorientated.
The severely melted piston was on cylinder 8. The badly stretched/concave intake valve was also on this cylinder.
Ive removed the Morel lifters, and I guess not surprisingly, the lifter cup was fully compressed, and its also free to move, as if the internal spring is broken. I dont have small circlip pliers handy to take it apart.
Yes it was lean etc etc etc. But.
I assume the lifter damage is caused by the stretched valve ? And there is no chance a failed lifter could have had an effect on the intake valve ?
If its as simple as an internal spring, can parts for these lifters be acquired for repair ? Or would a spring from a stock lifter suffice ?
The piston on that cylinder ( 8 ) is totally destroyed.....will be good to see it when its out. Its even loose on the pin.
In the case of this piston.....Im thinking that one of the injectors on that cylinder wasnt firing properly.... and me being stupid, I used PTFE tape when installing the NPT fittings on the rails. I knew at the time it wasnt a great idea, but it was all I had handy lol.
No doubt its clogged up with some particles of PTFE tape
You need to keep the timing at 20 and no more for 17-19psi with the YSi unless you are are going to run straight 110/112/114//116. I made 680rwhp at 18 psi thru a th400.
I'm boosting 15 psi on pump 93 and no meth right now, feels like high 9's and almost 140 but I'm 8:1 compression.
All of the pistons do show signs of heating, pickup etc.....but cylinder 8, the one with the stretched valve is by far the worst. I dont think Ive ever seen a piston so badly damaged in this respect.
Oddly too, it shows signs of hitting the crankshaft. It also fouls the reluctor wheel....although my last set of JE pistons did this too. When the engine was built and on the stand, nothing was hitting the piston.
This piston is also rocking about on the pin, which is very very loose in the piston.
The left hand cylinder bank, 1-7 has definately got away with less damage. Pistons arent great by any means, but not bad either. It also only melted 1 plug on that side.
Gasket surfaces in 1-7 also appear to have been sealing 100%
On 2-8, all 4 plugs were melted. Some cylinders were showing slight signs of gasket leakage, aside from the obvious big one where it blew.. But only very slight.
I'd try and get some better pics, but I dropped the bloody camera and broke the screen when I started taking it apart, and now I cant see what Im photographing properly.
That almost makes me feel better lol
Block scrap, pistons scrap, and head severely damaged ( I hope to F*** the head can be saved )
The only items that survived, are the crank and rods, and I hope the camshaft.
