Ms4 and Procharger
Old Sep 7, 2008 | 09:10 PM
DevonsZ's Avatar
Default Ms4 and Procharger
I know i'll have better power/drivabilty with a blower cam but for now how would this cam work with about 6-8lbs of boost? My motor is a Tsp 370 with ms4, stg2.5 ls6 heads, H beam rods, stock crank, .040 mls gaskets, etc....
Old Sep 7, 2008 | 09:12 PM
ninetres's Avatar
It will work. ANY cam will work. You will have to pulley up more than normal because that cam has a lot of overlap that will bleed boost. Run it with enough pulley for 8 spi and then get a more approipirate cam. you should pick up some good horse "pressure" after that
Old Sep 7, 2008 | 09:27 PM
DevonsZ's Avatar
Thanks for the quick reply.
