ls6 pvc valley conversion
Old Sep 12, 2008 | 10:30 AM
mmorellicamaross's Avatar
Default ls6 pvc valley conversion
I have a supercharged ls1 that is leaking oil through the pvc system, has anybody converted there ls1 pvc system to the ls6 valley with a positive outcome?
Old Sep 12, 2008 | 10:55 AM
7845's Avatar
i have the lS6 valley cover on my turbo build. i have bungs in each valve cover with a -10 line connecting each bung along with a -6 hose from the valley cover nipple to another Tee. all this goes to a breather/catch can over on passengerside. so far no issues
Old Sep 13, 2008 | 02:54 PM
CanII's Avatar
http://ls1howto.com/index.php?article=18
Bam!
Old Sep 14, 2008 | 12:02 PM
dschmittie1's Avatar
I have an LS6 valley on my car but I have my PCV just vented now. I know that you really can't use the fresh air tube that goes to the inlet hat because I had mine sucking oil though that when I was under boost. I am not sure that the conversion will help you much I think you will just be better off venting th PCV and being done with it.
